install FMEServer on remote platform (e.g. AWS)
I am looking for a configuration that would let me use FME from web client. I imagine I can install FMEServer for example on AWS EC2 and control it via REST API. But the fact that I haven't seen any tutorials/documentation about it, makes me thinking my assumptions might be wrong. My questions are:
1. What platform would be best for installing FMEServer remotely (for testing purposes – would a free of charge platform be preferred)?
2. Do you know any tutorials that would guide me through this process?
Thanks in advance
nielsgerrits
Forum|alt.badge.img+53
FME Cloud (FME Server on AWS): https://www.safe.com/fme/fme-cloud/
FME Server Playground: https://playground.fmeserver.com/
FME Server REST API documentation: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html
Forum|alt.badge.img+49
I use FME Server on AWS for my training courses, I think you get an x number of hours for free if you sign up but otherwise the cost of the VM's I pick is in the $0.15-$0.20 per hour range. FME Cloud, as @nielsgerrits suggests, can be interesting too. If you sign up there you get $250 credit and the basic model, on-demand, runs at $0.90/hour so you can get quite some testing in for that.
Management is through a web interface anyway and as for tutorials, check out the recorded training courses here.
  • February 26, 2019
Thank you both for answer.
To clarify my question I created new thread:
https://knowledge.safe.com/questions/87569/connect-fmeserver-on-remote-host-what-ip-what-url.html
