Inserting a filled database table into a template table
Hello community, I'm quite new to fme and I've been stumbling on something that might be easier than i think. Basically i have a filled access database table and I'm trying to fit these filled records into a template table. This template has less column headers/attribute names than the source. I'm trying to get the values that do no longer have a place to be put into a string. I have managed that, however I'm trying to have this long string be readable by having the attribute value be preceeded by the attribute name. I'll give an example below: (sorry I'm currently only on mobile so writing it out is a bit harder)
Old
Fruits vegetables grains soup
Apple cauliflower bread tomatosoup
New:
Fruits vegetables other
Apple cauliflower grains: bread, soup: tomatosoup
This is just an example. The real table has like 52 fields per records that has to fit into 30. I hope anyone can help me out.
Best answer by takashi
Hi @senteria, If you know which attributes should be integrated into the "other" field, you can just create desired value with AttributeManager (or AttributeCreator or StringConcatenator), as in:
Forum|alt.badge.img+22
  • February 24, 2020
  • February 24, 2020
Thank you so much, Takashi! The answer was in front of me all along but i have been staring myself blindly. I was using a schema reader and had split the attribute names from the source table with a feature merger. I was trying to automate it by having it read the structure and automatically combine the attribute names that do not match the schema be put into a new attribute. Thanks again for the solution. I am not sure what i was attempting is even possible.
  • February 24, 2020
You can use the Schema Reader to read schema from the source table and the template table, create a list attribute (e.g. "_other{}.name") containing attribute names that should be aggregated into the "other" attribute, and then merge the list to every data feature unconditionally, with this workflow for example.
After that, however, I think you will have to write a script (Python, Tcl or so) to create the "other" attribute.
PythonCaller Script Example:
def aggregateOthers(feature):
    items = []
    attrs = feature.getAttribute('_other{}.name')
    for attr in attrs:
        value = feature.getAttribute(attr)
        items.append('%s:%s' % (attr, value))
    feature.setAttribute('other'', '.join(items))
  • February 25, 2020
    items = []
    for attr in attrs:
Thank you so much Takashi, this works precisely as I hoped for! Do you per chance know how I can make it so the 'other' attribute string only contains attributes that are filled and not empty? i.e. In case 'grains' has no value, I would like it to be left out in the string. I think the solution for this lies in the python script where it needs a clause line. Unfortunately I have yet to learn python scripting. I suppose it's something along the lines of 'if attribute value has a value' -> combine.
  • February 25, 2020
This script combines "other" attributes except null, missing, empty, and numeric 0. If it's sure that every attribute never stores numeric 0, this script would be enough.
    items = []
    for attr in attrs:
        if value:
However, if the attribute might contain numeric 0, a bit more strict conditional expression would be required, like this.
    items = []
    for attr in attrs:
        if value != None and value != '':
  • February 25, 2020
    items = []
    for attr in attrs:
        if value:
    items = []
    for attr in attrs:
This is perfect and precisely what I was looking for. Thank you very much for your time and help. Greatly appreciated.
