How can I export 3D building, textures, and attribute from Revit 2017 using FME exporter for Revit to ArcScene?
Hi, Could anyone please help me to transform the 3D object from Revit to ArcScene? I exported the 3D using FME exporter to get RVZ file, however, when I tried to visualize the result in FME data Inspector, the texture of the building wasn't appeared or transformed. I am not sure of the options I have to choose from the Export dialog to export the texture. Any Idea?
Also, I transformed the RVZ file as it is (without texture) using FME Workbench Desktop to Shapefile and I have noticed that the multipatch layers for the building didn't come/merge in one attribute in ArcScene, and of course the texture was not appeared as well.
Thank you,
Be the first to reply!
