Export GML with Date attribut using Dynamic Reader and Writer
  • August 29, 2024
  • 5 replies
  • 107 views
dxirgu
Forum|alt.badge.img+4
Hi everyone,
I have a workflow that exports data from Oracle to another formats, like Shp, GML... using dynamic readers and writers.
This workflow recive some parameters, like table name, that is used to read de Oracle table and to write the file name. The question is about GML file and date values.
When the Oracle table has datetime attribute, FME exports as text, by default.
I've achived that FME exports GML with attribute as date type, but this attribute has null value, beacause the format of date is wrong. That is, the exported date value is "19630904000000" but it shoud be "1963-09-04".
As I said, I use dynamic readers and writers, beacuse I don't know what table will be exported and I can’t see the table structure, neither, when data goes out by Generic port of Reader. So I can't use StringReplacer and DateTimeConverter, because I would need to know the name of attibute.
Anyone has any idea how to modify the format of the date?
hkingsbury
Forum|alt.badge.img+53
  • September 2, 2024
From the oracle data, are you able to identify what fields are meant to be datetimes?
In the DateTimeConverter you can specify either the attribute (_creation_instance) or to use the value that _creation_instance (@Value(_creation_instance)) contains
dxirgu
  • September 2, 2024
Hi @hkingsbury ,
Sorry, I don’t get “_creation_instance” values from the Reader. I get the input parameters and “fme_feature_type_name” value. Could the problem be in the configuration of Reader?
Tkanks!
bwn
Forum|alt.badge.img+26
  • September 2, 2024
Well, my solution abuses BulkAttributeRenamer, RegEx and List Attribute naming convention, and is complex…..but it works.
Frankly though, I would probably just write something in PythonCaller, but the below works for out-of-the-box Transformers.
Step 1 is to get Attributes that are Date/Time from the Schema Features from a FeatureReader
Step 2 is to Join these with the Dynamic Feature Reader Output.  In this case, there are 11 Date/Time Attributes for the 100 Sample Features, so this gives 11 x 100 Joins.  This gives a “Grid” of Values, where each of the 1,100 Features represents 1 Date/Time Attribute “Cell” 11 columns of date/time Attributes x 100 Features to give 1,100 Features to operate on.
Step 3 is to temporarily rename each Date/Time Dynamic Attribute to static/known Name by abusing BulkAttributeRenamer, which can work well as a type of  “Dynamic Schema AttributeCreator”
So now we have a “Table” from this that is _count (Workspace Unique Feature ID), fme_feature_type (Table Name), name (of date/time Attribute) and “_date_col” which is the temporary known and exposed name of the Date/Time Attribute
Step 4 is to find which Attribute “Cells” have a valid FME Date/Time value, and convert them to Y-m-d
Step 5 is to know  a bit about how Lists work in being just a collection of Attributes that happen to have their Name as in a format like _list{1}.Attribute Name .  If we remove the _list{1}. part of the List Attribute Name by again abusing BulkAttributeRenamer, then they become just standard Attributes as far as the Workspace is concerned.
So now we use a FeatureJoiner with Override from the Right set up to replace the original FME format Date/Time Attribute Values with the new DateTimeConverter String values.
So waaay more complex than I expected to “Dynamically” find Date/Time Attributes in a Dynamic Reader situation.  It would be a lot simpler if could have a Transformer like AttributeCreator that could perform in a dynamic “Attribute Scan” type mode that could traverse all Attributes and use Eg. Conditional Values. 🤨
Or as above, I would probably just write a Custom PythonCaller...
nielsgerrits
Forum|alt.badge.img+54
The easiest way is probably to get a SchemaScanner to generate a valid schema feature?
I tried a bit and this might be harder than I suspected initially. The SchemaScanner does not seem to work as I hoped it would.
I would try what is suggested here.
hkingsbury
  • September 3, 2024
dxirgu wrote:
Hi @hkingsbury ,
Tkanks!
_creation_instance is just an example of an attribute, substitute it with the attribute that contains the field names
