Error in opening the configured workspace
  • Apr 4, 2019 7:48 PM UTC
  • 40 views
Hello,
In my current setup I have serverJobSubmitter which may be executed even few thousand times in one JOB.
I noticed that it goes great for about 2000 executions and then I start receiving error:
BADNEWS: FMEWorkspaceRunner: Error in opening the configured workspace (fmeworkspacerunner.cpp:468)
FMEServerJobSubmitter_2(ServerJobSubmissionFactory): Failed to complete run of workspace ...
I also noticed that log file is growing rapidly and at moment when it starts failing it is ~600 MB big but I can't say if it is always the same.
I checked that still there is enough disc space for logs.
Session duration was around 27 hours and then it started to throw that error without any additional information.
Best answer by siennaatsafe
Hello @witos,
Thank you for contacting us. I know we just spoke on Live Chat, however, I thought it would be good to answer this question publically so if anyone else encounters it they will have the answer as well.
So, unfortunately, you have stumbled upon a bug we had in FME Server 2016.1. Where if the FMEServerJobSubmitter was used for 1000s of jobs it would produce an error.
This bug has been fixed of build 16167 and build 17160.
Kind regards,
Sienna
siennaatsafe
Forum|alt.badge.img+12
  • Apr 4, 2019 9:29 PM UTC
Hello @witos,
Kind regards,
Sienna
