Convert each list element to multiple new attributes
I am trying to create a new attribute for each element in a list. The tables below show the desired outcome. Here is an explanation.
For every item in the MASTER list I am loading its corresponding detail list and saving it as a parameter. I want to take the corresponding list and transform it to the example below. I could accomplish this with a database view or query, but would like to be able to do it in FME.
I can assume that all ITEM_NAME values are known, which means all the possible attributes that I need to add could be added ahead of time if needed. Note that for every record in the master list, it won't have all of the possible ITEM_NAME values. My process right now is very brute force, and I am thinking there may be a transformer I haven't found that does this or a variation of this easily.
MASTER List
IDNAME1Bill2Sally
DETAIL List
MASTER_IDDETAIL_IDITEM_NAMETYPECOLOR1AShirtLongRed1BPantsJeansBlue2CShirtShortGreen2DPantsDressPurple2EHatBaseballRed
Transformed Master List with Detail Denormalized
IDNAMESHIRT_TYPESHIRT_COLORPANTS_TYPEPANTS_COLORHAT_TYPEHAT_COLOR1BillyLongRedJeansBluenullnull2SallyShortGreenDressPurpleBaseballRed
Thanks, Tom
erik_jan
Forum|alt.badge.img+17
  • July 20, 2017
The first step would be to join the master list items to all detail list items using the FeatureMerger (create a list for multiple details).
Assuming the details are always ordered you could the create the attributes with AttributeCreator (or AttributeManager) using the "Conditional Values" option (e.g. SHIRT_TYPE = if _list.ITEM_NAME = "Shirt" Then TYPE Else Null).
Hope this gets you in the right direction.
  • July 20, 2017
Hi @t2, I think this workflow does the trick.
  1. BulkAttributeRenamer: Add a prefix (upper case item name and an underscore) to the attribute names "TYPE" and "COLOR".
  2. FeatureMerger: Merge DETAIL List to MASTER List joining on ID of persons. Important: Set 'Yes' to the Process Duplicate Suppliers parameter.
  3. AttributeExposer: Expose the prefixed attribute names.
  4. AttributeManager: Remove unnecessary attributes.
Alternatively, the InlineQuerier works as well.
InlineQuerier | SQL Query:
select
    a.ID,
    a.NAME,
    b.TYPE  as SHIRT_TYPE,
    b.COLOR as SHIRT_COLOR,
    c.TYPE  as PANTS_TYPE,
    c.COLOR as PANTS_COLOR,
    d.TYPE  as HAT_TYPE,
    d.COLOR as HAT_COLOR
from "MASTER List" as a
left outer join (select * from "DETAIL List" where ITEM_NAME = 'Shirt'as b
    on b.MASTER_ID = a.ID
left outer join (select * from "DETAIL List" where ITEM_NAME = 'Pants'as c
    on c.MASTER_ID = a.ID
left outer join (select * from "DETAIL List" where ITEM_NAME = 'Hat'as d
    on d.MASTER_ID = a.ID
Hope this helps.
  • July 21, 2017
@takashi, Thanks, I appreciate both options. The second option you gave was inline with my fallback to sql, but I wanted to try it more along the lines of what you did in the first option, so thank you for both!
Tom
smfks911
  • July 4, 2022
Hi @Takashi Iijima​, I am following this thread and your solutions are really very effective. Slightly like similar problem, I would like to create two attributes by splitting a 'Road_name' attribute. So when road name is like Harris Rd, I will split them into two attributes 'type' and 'name' by recalling _list{1} and _list{0}. but when the Road_name has three words like David Conway St, I cannot simply do it by recalling _list{0,1}. What else I can do for such situation?
