Capturing Errors in FME Server Log files
  • December 16, 2017
  • 8 replies
  • 119 views
Can someone please explain how I can capture the Errors in the log file created by FME Server using Python. From what I have read I am still not sure if the python has to go in the startup, shutdown or PythonCaller transformer to capture any errors while it is running. I am also not a python developer so would appreciate a full working script or an example Workspace if possible? I am using FME 2016.
  • December 16, 2017
Hi @johnm, this Shutdown Python Script collects all lines containing "|ERROR" from the log file and save them as a list called "errors".
# Shutdown Python Script Example
# Collect error lines from the log file.
import fme
errors = []
with open(fme.logFileName, 'r'as f:
    errors = [line for line in f.readlines() if 0 <= line.find('|ERROR')]
Then, what do you want to do using the error lines? For example, if you want to overwrite the log file with only the error lines collected, add these lines after the script above.
# Overwrite the log file with only the error lines if there were one or more error lines.
if 0 < len(errors):
    with open(fme.logFileName, 'w'as f:
        f.writelines(errors)
  • December 16, 2017
import fme
errors = []
if 0 < len(errors):
This is a bit advanced configuration that uses both Startup and Shutdown Python scripts.
# Startup Python Script
# Add a function that collects error messages to FME Log File module.
import fmeobjects
errors = []
def errorCollector(sevirity, message):
    if sevirity == fmeobjects.FME_ERROR:
        errors.append('%s\n' % message)
fmeobjects.FMELogFile().setCallBack(errorCollector)
# Do something using the collected error messages.
# e.g. overwrite the log file with the error messages if there were one or more errors.
import fme
if 0 < len(errors):
  • December 17, 2017
import fme
errors = []
if 0 < len(errors):
I don't remember if FME 2016 has the FMEServerLogFileRetriever, but if there were, you could also create another workspace to run the workspace with an FMEServerJobSubmitter and retrieve the entire translation log as an attribute using the transformer. Since the log is a plain text, you can parse/analyze it to retrieve required parts.
  • December 17, 2017
Hi @takashi, I forgot to mention that I need to write the errors into an Oracle table but I am not sure how I could do this until I get some example output data. Also, as I had in another question, the LogMessageStreamer was what I was trying to use but found it difficult to get it to run at the end of the script to capture all the errors.
  • December 17, 2017
In the case, I think it would be easy to create another workspace containing the FMEServerJobSubmitter and the FMEServerLogFileRetriever as I commented in the previous answer, if FME 2016 supported those transformers.
  • December 17, 2017
Regarding the LogMessageStreamer, I don't think it's suitable to your purpose because it has this limitation "Messages outside the lifetime of the transformer cannot be captured" -- LogMessageStreamer Help.
Vote up this idea :-) ErrorCatcher Transformer
  • December 17, 2017
Hi @takashi Thanks for the above, I will use the python method you suggested as the startup & shutdown scripts work fine. How do I write the error messages into an Oracle table?
  • December 17, 2017
Since Python standard library doesn't support Oracle database connection, you will have to obtain additional module such as "cx_Oracle" and configure your FME Server so that the additional module can be run.
I myself have never experienced that, so cannot help you unfortunately. See a relevant section in FME Server documentation, and ask help of other experts if necessary.
Although it should be theoretically possible to connect Oracle database using a Python script, it could be a little troublesome to configure the environment of FME Server. If I were you, I would try first the method that uses the FMEServerJobSubmitter and FMEServerLogFileRetriever, in order to avoid make FME Server maintenance more complex.
