Attribute Name User Parameter
  • Feb 28, 2019 2:02 PM UTC
  • 99 views
pflegpet
Forum|alt.badge.img+8
is there a way to restrict the "attribute name" parameter to specific attribute names. I use it for chosing the attributes of an Excel file that has lots of attributes so the drop down list gets very busy. I tried to use the choice parameter as an alternative but it seems you can only use it for attribute values not names. Thank you for your help.
  • Feb 28, 2019 2:37 PM UTC
Hi @kasparlov, I think the Choice parameter could also be used to specify an attribute name, depending on where the parameter is referenced.
Where/How the parameter is referenced in the workspace?
arnovananrooij
Forum|alt.badge.img+5
Hi @kasparlov, you could add a published parameter of type attribute list (comma delimited) and use this parameter in an AttributeKeeper
pflegpet
  • Mar 1, 2019 6:43 PM UTC
Hi @takashi, I would use the parameter in a Tester: Parameter: Attribute has a value.
  • Mar 1, 2019 10:54 PM UTC
I think a Choice type parameter and the != operator could work as your expected.
