Streaming Service Base URL Wrong in 2019.1
mmccart
Forum|alt.badge.img+16
I upgraded FME Server to 2019.1 and my streaming services are failing. It appears that 'FME_SERVER_WEB_URL' in the request did not pick up the change when I enabled HTTPS during the install. It is still showing the original HTTP url with Port 8080 (http://SERVERNAME:8080). Is there another file besides fmeServerConfig.txt that needs to be modified?
I have a distributed architecture deployment: All components are on a single machine except the Web Services component, that is on a separate machine. I upgraded from 2019.0.1 to 2019.1 and now my streaming services are not providing an output.
Thanks in advance.
-Mark
Best answer by david_r
I can only recommend that you read through all the steps here and check that you didn't miss anything:
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/configuring_for_https.htm
  • July 18, 2019
You probably need to update the service URLs in the FME Server GUI, under the Services section.
mmccart
  • July 18, 2019
Sorry @david_r, I should have included that in my post. That piece is done. All of the match the correct base URL.
  • July 18, 2019
mmccart
  • July 18, 2019
Thanks. I missed one step.
