Is possible to have FME Desktop and Server in windows and License manager in Linux
Want to build a set up license manager in Linux and FME Desktop and server in windows os. Please let me know is this possbile
Forum|alt.badge.img+49
Yes, that should be no problem. FME Server has its own licensing mechanism so it's independent of the FlexLM license manager.
sipsysigh
Forum|alt.badge.img+7
  • November 21, 2019
Hi @msrnivasan,
Yes, this is possible. I would take a look at this documentation first to highlight some of the considerations for installing a Floating License on Linux, particularly the Before You Begin page:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Installing_Floating_License_Linux.htm
If the relevant network configuration changes for FME Desktop to communicate with the license server are made, then you should be good to go.
Thanks,
Simon
