Writing to dwg surface
  • Jul 6, 2020 1:50 PM UTC
  • 118 views
sprongandre
What are the settings (writer and additional attributes) to write to a dwg-surface?
So for example to convert a pointcloud to a surface (dwg)
Now when I would like to write it to dwg it becomes a mesh (object ;-) ).
Thanks!
Forum|alt.badge.img+63
Are you just writing straight to DWG or are you doing something in between (e.g. a SurfaceModeller)?
sprongandre
Hi @redgeographics, that's exactly the question ;-). Now I tried different transformers to create a surface from some objects and then write to dwg but I only get meshes :-S
