VariableRetriever and Custom transformer
  • November 29, 2012
  • 89 views
Hello,
I have a variable set Globally outside a custom transformer (that is also being called via 2 other source datasets).
Within the Custom Transformer I have the VariableRetriever with the variable name I used in the VariableSetter and I set the destination Attribute and click OK.
If I bring up the properties again, the attribute field is blank.
Does the VariableSetter / VariableRetriever not work when using Cusotm Transformers or is there a bug?
Version: FME(R) 2012 SP2 (20120410 - Build 12235 - WIN32)
Hello,
I reproduced your case with FME 2012 SP4 build 12266. I was able to set the properties of the VariableRetriever in the Custom Transformer (in embedded mode) and when I reopened the VariableRetriever the attribute field was still set with the value.
So when I reproduced it correctly it should work with SP4...
Hope that helps,
best regards,
Stefan
Hello,
Hope that helps,
best regards,
Stefan
