Transfer measures on points to coincident polyline vertices?
I have a set of geodb_points with measure values on their geometry as well as stored in an attribute for each point. I want to assign these measure values to the vertices of geodb_polylines and preserve all other attributes of the polylines. Note that the points are coincident with the vertices of the polyline. How can I transfer the measures on a point to a coincident vertice on a polyline?
Best answer by fmelizard
I would break up the line using the chopper, relate the points (SpatialRelator) and vertices and re build the line (LineJoiner).
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
