Thrim white borders of a tiff
  • April 28, 2016
  • 130 views
Hi, I have some large 1 bit single band tiffs and I want trim the empty white space from each edge of the image.
Maybe 25 pixels from the 1st black pixel found on each border if possible.
I think I need to determine the 1st black pixel from the border on each side then use this info to create a polygon to clip the image.
I just have no idea how to work out the area I want to clip within the workbench, not much of a raster expert.
Best answer by jdh
Assuming your borders are not regular:
Set the white pixel to NoData
Use the RasterExtentsCoercer in DataExtents mode
HullAccumlator to get a single output polygon with no holes
Buffererer (-1*#pixels*pixel_size)
jdh
Forum|alt.badge.img+41
  • April 28, 2016
  • April 29, 2016
geat thanks, I do want regular borders so have adjusted the RaterExtentsCoercer to use DataMBRExtents.
Some twueking to do but looks like I can achieve what I want with these transformers, thanks for the help.
