Rastertiler and it worked fine. why doesn't tiler work the same on a vector file?
  • Feb 14, 2018 5:34 PM UTC
  • 72 views
Trying to tile a Microstation DGN file into tiles. Used Raster tiler on an ECW and that worked fine. It appears that Tiler doesn't work the same on vector files. Why is that?
jdh
Forum|alt.badge.img+41
  • Feb 14, 2018 6:54 PM UTC
The RasterTiler starts 0,0 in the lower left corner, and the Tiler in the upper left corner, but otherwise they are mostly the same.
What problem are you having?
  • Feb 15, 2018 8:12 PM UTC
I have vector data and raster data and I want to be able to tile and name them the same.
jdh
  • Feb 15, 2018 8:14 PM UTC
Then use the Tiler for both the raster and vector data. Don't use the RasterTiler at all.
