Question: What parameters do I add to the attached workspace in order to get the result of the building in its correct location? Thanks to everyone who helps me.
  • Aug 23, 2022 7:56 AM UTC
  • 47 views
mohamdwassouf
After an effort, a building was converted from IFC format to citygml format
 And then converting from citygml to shapefile
It is now necessary to adjust the construction site on the map so that it descends to its correct location
The correct location for construction is attached to the picture3
daveatsafe
Forum|alt.badge.img+24
  • Oct 19, 2022 9:55 PM UTC
Hi @mohamdwassouf​,
I usually use a combination of Offsetter, Rotator and LocalCoordinateSystemSetter to georeference BIM data when there is a point in the model with a known latitude and longitude. I am attaching a simple workspace with just these transformer so you can cut and paste into your own workspace. They also include the User Parameters needed to set the point location, units and model rotation from true north.
