Point on raster value extractor: How to give z coordinates to points depending on their position on a geotiff?
  • September 19, 2017
  • 258 views
Hi @pepote, the PointOnRasterValueExtractor adds a list attribute called "_band{}" to each point that is inside of the source raster, and the "_band{}.value" contains the values of all bands at the cell that matches the point. For example, if the first band of your raster represents elevation, "_band{0}.value" will store the elevation. Then, if your goal is to assign the cell value to z-coordinate of the point, you can use the 3DForcer transformer by setting "_band{0}.value" to the Elevation parameter.
danilo_fme
Forum|alt.badge.img+57
Hi @pepote,
I simulated your case in my machine with just a point and a raster file ( DEM ).
The transformer PointOnRasterValueExtractor was used and a new attribute was created after this transformer:
After i used the transformer CoordinateExtractor and in the options inside this transformer, the value for Z was configurated by value attribute _band{0}.value:
The result:
Thanks,
Danilo
  • September 20, 2017
It works... thanks a lot!
