Merging Improper
  • Dec 16, 2014 7:10 AM UTC
  • 5 replies
  • 47 views
parashari
Working on Win-7, 8Gb
I have a polygon area where Country is Order 1, State 7 and City 8. Be it, img below:
I want output in the following manner:
The Red is what I am getting and Green is what I want:
Is there any way that we can apply to get the desired output. Thanks (:
  • Dec 16, 2014 8:24 AM UTC
have you looked into the SpatialRelator? Specifically, the contents of the relationships list generated by the transformer.
David
parashari
  • Dec 16, 2014 8:57 AM UTC
Hi David,
I tried SpatialRelator and SpatialFilter, but couldn't get the desired output.  Serially or Parallelly, either ways its not working ):
  • Dec 16, 2014 1:17 PM UTC
Hi, I believe the SpatialRelator should work in this case.
How did you use the transformer?
Takashi
gio
Forum|alt.badge.img+15
  • Dec 16, 2014 2:11 PM UTC
I think u need to check naming confilct.
Rename the attributes on either the supplier or requestor (else it will yield empty fileds).
You can then re-rename relevant fields once the relation is made.
parashari
  • Dec 17, 2014 5:49 AM UTC
Yes, I tried spatial filter. Now its working fine. I gave multiple basses and candidates and I got the correct thing. Still I am unsure how I got it :/
Anyways, Thanks all (:
