Lines from Polygon layer in Aggregate?
  • November 13, 2013
  • 81 views
lorinda
Hi All,
I'm using raw data of the parcel_polygons and attempting to aggregate the ones that are non-contiguous but have the same parcel id, of which there are approximately 1000, the rest are not with a duplicate parcel id.  I thought that the transformer/function to use was Aggregate, however when I use it with or without the GeometryFilter I keep getting the following message
"INFORM|Transaction #11 was successfully committed
2013-11-12 18:39:17| 456.8| 0.8|ERROR |Cannot write a non-area feature to an area feature class
2013-11-12 18:39:17| 456.8| 0.0|STATS |Storing feature(s) to FME feature store file `J:\\Fme/fgdb2oracle_mergeparceldata_log.ffs'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Feature Type: `ParcelsAggregated'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(encoded: utf-16) : `PID' has value `272223083000040'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(64 bit real) : `Shape_Area' has value `3159.85499801344'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(64 bit real) : `Shape_Length' has value `426.027720073092'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(string) : `__wb_out_feat_type__' has value `ParcelsAggregated'
Attribute(string) : `fme_geometry' has value `fme_aggregate'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(string) : `fme_type' has value `fme_area'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(string) : `geodb_type' has value `geodb_polygon'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(string) : `multi_writer_id' has value `0'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Attribute(32 bit unsigned integer): `numofparts' has value `1'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Coordinate System: `FL83-EF'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Geometry Type: Multiple Geometry
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Front Appearance Reference: `<inherited_or_default_appearance>'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Back Appearance Reference: `<inherited_or_default_appearance>'
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Number of Geometries: 1
2013-11-12 18:39:17| 456.8| 0.0|ERROR |--------------------------------------
2013-11-12 18:39:17| 456.8| 0.0|ERROR |Geometry Number: 0
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Geometry Type: IFMEMultiArea
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Number of Areas: 2
2013-11-12 18:39:17| 456.8| 0.0|ERROR | --------------------------------------
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Area Number: 0
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Geometry Type: IFMEPolygon
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Boundary:
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Geometry Type: IFMELine
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Number of Coordinates: 22 -- Coordinate Dimension: 2
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468157.368973354,1538764.76304782)(468156.732154372,1538683.91002765)(468156.629996814,1538670.93970604)(468156.596773771,1538670.93868901)(468150.272935885,1538670.74510213)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468150.262105685,1538675.4200061)(468137.691558107,1538675.39088431)(468137.679171877,1538680.73745058)(468137.671072453,1538684.23360315)(468138.398973031,1538684.23528946)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468138.929692681,1538752.43276525)(468133.723417249,1538752.47328101)(468133.604392825,1538737.17864361)(468114.598888909,1538737.32654636)(468114.598888909,1538759.77497345)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468114.915205088,1538759.75740034)(468114.920022251,1538760.63894022)(468109.731412936,1538760.66729327)(468109.742848999,1538764.81290359)(468116.827602978,1538766.14272796)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468149.621538704,1538772.29822399)(468157.368973354,1538764.76304782)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Area Number: 1
2013-11-12 18:39:17| 456.8| 0.0|ERROR | Number of Coordinates: 7 -- Coordinate Dimension: 2
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468132.102207298,1538731.65034003)(468131.87128331,1538700.55257629)(468114.961783083,1538700.6781419)(468109.566037583,1538700.71820931)(468109.593947173,1538710.83552356)
2013-11-12 18:39:17| 456.8| 0.0|ERROR | (468109.651826747,1538731.81705078)(468132.102207298,1538731.65034003)
2013-11-12 18:39:17| 456.8| 0.0|ERROR |===========================================================================
2013-11-12 18:39:17| 456.8| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details"
It appears that it is kicking out lines from the polygon layer - how is that possible?  ESRI doesn't allow lines and polys on the same layer.  I've got the geometry filter in there as well and kicking only 'area' through.  It is working for at least 11K of the 432K features before I get this error.  I haven't even started the join at this time, only reading the polys, sort them, then filter, then aggregate and write the new geometry.
Any insight is greatly appreciated.
Thanks,
Lorinda
fmelizard
Forum|alt.badge.img+22
  • November 13, 2013
HI,
have you tried deaggregating before the aggregation?
Itay
lorinda
  • November 13, 2013
No, can you give some explaination as to why that would be needed?  I've been told that this layer is the individual parcels before they are merged and additional data attached.
Thanks, L~
fmelizard
  • November 13, 2013
I prefer to check it myself, thats all.
Place a AggregateFilter and see for yourself, I could be wrong too....
