lat lon to geometry
  • Aug 14, 2020 10:02 PM UTC
  • 5 replies
  • 104 views
lat lon to geometry
csv ot geom
danilo_fme
Forum|alt.badge.img+58
  • Aug 15, 2020 2:34 AM UTC
Hello @pbiffar​
If I understood your doubt, you want to read a CSV file and extract lat and long, by last geospatial these points, correct?
If yes, you can use the transformer VertexCreator to Replace with Point.
Thanks,
Danilo
  • Aug 15, 2020 3:44 AM UTC
take the csv lat lon and create point geom, I think I found that it does that automatically?
Here is a more complex question.
I have csv A and csv B of the same data columns. Let's say A is from July issue of data and B is August issue date. Some of the data is the same in both, some is updated, some is new in B, some is in A but not in B
Assume data has a unique id numbers.
Is there one or a combination of transformers which identify.
  • what rows are in A but not in B
  • what rows are in B not in A
  • what is identical in A and B
  • what rows have changed in A versus B, ideally which fields of the row have changed
  • Aug 15, 2020 1:22 PM UTC
Hi @pbiffar​ , as @danilo_fme​  suggested, you can use the VertexCreator to create a point from the two column values - lat and lon.
Alternatively you can also create a point geometry directly from the two column values for each record if you specify attribute types "x_coord" and "y_coord" for the two columns through the reader parameters dialog when adding the CSV reader, as in:
csv-reader-parameters-attributes
Regarding the second question, the ChangeDetector transformer might help you.
danilo_fme
  • Aug 15, 2020 3:50 PM UTC
Thanks @Takashi Iijima​ to endorse the answer :)
