Issue while updating AND inserting data in Esri Geodatabase (File Geodb) writer
Hello,
I have a geodatabase file to update with FME : some features must be updated, et some new features must be inserted in that geodatabase file. Those features are polygons with several attributes.
First in my script, I read the geodatabase file. Then I change some values and create new ones.
Finally, I use a "Esri Geodatabase (File Geodb)" writer to update former data and insert new data at the same time. I chose feature opeartion "upsert" and table handling "create if needed".
When I open the resulting "updated" gdb file in Arcgis Pro, I can see the updated data and... only part of the new features. There are several of them missing ! But why ?
Here is what I should have :
what I should have
And here is what I get :
what i have
Am I doing something wrong ? Is there a way to correct this ?
joepk
Forum|alt.badge.img+20
  • September 12, 2023
Do you correctly preserve the unique field used to update the features? If there are duplicate values in this column this could be the cause of your issue.
You could also create an attribute called "fme_db_operation" and set it to INSERT for features you want to insert and UPDATE for features you want to.. well.. update. You can then set the Feature Operation in your FeatureWriter to fme_db_operation and it will base the operation on the value in that field.
I usually use the Use Existing option in Table Handling, this way some attributes generated during analysis won't accidentally end up in my gdb.
Here's how this all looks in my FeatureWriter transformer:
kimo
Forum|alt.badge.img+10
  • January 20, 2025
No answer after a year? My first reaction is that a filegeodatabase is file based. That is you cannot read and write at the same time. So I would avoid having a reader and writer to the same database in the same workspace. Get around this by making a copy of the database to read. Maybe FME closes the database before writing? Maybe not.
