Is their any document or link which can help us understand intergraph gtech electric data model.
  • May 15, 2020 7:49 AM UTC
  • 99 views
helmoet
Forum|alt.badge.img+8
  • May 15, 2020 6:27 PM UTC
Hi @sandeepchettu, would this help for you, which is for me the base of the Intergraph component model:
select g3e_feature.g3e_fno
     , g3e_feature.g3e_username
     ,  g3e_feature.g3e_tooltip
     ,  g3e_component.g3e_cno
     ,  g3e_component.g3e_username
     ,  g3e_component.g3e_table
     ,  g3e_component.g3e_tooltip
     ,  g3e_component.g3e_lrno
     ,  g3e_component.g3e_type
   from g3e_featurecomponent
   inner join g3e_feature on g3e_feature.g3e_fno = g3e_featurecomponent.g3e_fno
   inner join g3e_component on g3e_component.g3e_cno = g3e_featurecomponent.g3e_cno
order by g3e_component.g3e_cno;
You might find more on this subject on this location.
I need to migrate data from integraph gtech to fgdb using FME,here using above query provided can i map feature to feature respectively.
helmoet
  • May 19, 2020 7:41 AM UTC
Hi, that's An impressive job. You will probably start reading Oracle spatial and using g3e_geometry as geometry. You will need every component of the query above and translate it to fgdb feature. A SchemaMapper may come in handy for this, I suppose there is a large number of features to migrate? You could throw in another join to the g3e_attribute table to see field properties. Older versions use Oracle spatial relational. That is, IF your customer is using Oracle.
