I have an Excel file, which has the following column with this data"POLYGON ((4.810746 52.862204, 4.812784 52.861478, 4.814501 52.863421, 4.812677 52.864069, 4.810746 52.862204))"
  • Sep 28, 2023 12:48 PM UTC
  • 38 views
nick3_s75
Also "MULTIPOLYGON (((4.9086662233849 52.753664580098, 4.9151035250207 52.749014947513, 4.9148889482994 52.748742188294, 4.9156828821679 52.748157698504, 4.9128719271203 52.746547063843, 4.9067350328942 52.750989153809, 4.9072071016808 52.751261898961, 4.905790895321 52.752222987318, 4.9086662233849 52.753664580098)))"can i create a geometry with this data?
Forum|alt.badge.img+63
Yes, that is a OGC WKT geometry description. You can use the GeometryReplacer to do that, select the correct encoding (OGC Well Known Text) and the attribute. Then use a CoordinateSystemSetter afterwards to set the correct coordinate system, I am assuming LL84 in which case these geometries end up somewhere in Noord Holland.
nick3_s75
  • Sep 29, 2023 7:42 AM UTC
Thanks for the answer, it works
