I have a very large 3D OBJ file and wanted to convert to 3D Cesium Tiles. The Cesium Writer only creates to tile outputs that are huge (650-900 MBytes). Is there a way of introducing LOD and enable more tiles to be created with smaller tile size?
  • Jul 6, 2023 9:46 PM UTC
  • 5 replies
  • 602 views
itsmatt
Forum|alt.badge.img+48
  • Jul 7, 2023 8:00 AM UTC
As far as I understand it FME 3DTiles writer will keep the features/mesh as a whole. It will not cut/clip a mesh to create smaller tiles. In addition there is no generalisation performed on the geometries.
FME attempts to create smaller files by down-sampling the textures.
While FME can clip 3D features now it still can not properly clip a textured mesh.
You can try this tool: https://github.com/OpenDroneMap/Obj2Tiles
It works to convert OBJ directly to 3DTiles. It might not scale so well to your large OBJ but it might be just what you're looking for
Thanks for your quick response. I use Obj2Tiles for this conversion, but it seems to take a long time to convert LARGE OBJ files. On one project it took over 24 hours to tile a 1.5 GB Mesh into 5 LOD Tile. On smaller files it does great.
itsmatt
  • Jul 7, 2023 12:10 PM UTC
Thanks for the info - Long processing times on 3D Datasets like this aren't sooo uncommon. It's a lot of operations that it has to do. But a quicker process would be nice for sure. If the output is great and it's stable then that's a really big win.
featuremichael
Forum|alt.badge.img+9
Hey Guys, what is with the parameter settings in the cesium 3d tiles writer ?
ParametersMaximum Number of Triangle Faces per Tile = Smaler tiles. 😎
and after this operation, i would use the github files.
itsmatt
  • Jul 12, 2023 9:58 AM UTC
This only works per feature - FME doesn't split the features as far as I know - certainly not if the input features are mesh geometries
