HullReplacer - placing geometry at specific calculated altitude
2021-03-22 14_22_37-FME Data Inspector - 2021.0Hi everyone and thanks for your time
I've used HullReplacer in order to get my polygon, see attached - but is there a way to place it FLAT at the calculated lowest point of the object.
Thank you
Best answer by daveatsafe
joolek.o wrote:
Thanks @daveatsafe​
I have tried BUT... It's most likely me being an amateur
Please see below:
My overlay is crated based on the TIN from the LAS, When I use Bound Extractor it creates one big for all the objects instead of multiple small ones...
Hi @joolek.o​ ,
OK, it's a little more complex, but you can try the following process:
  • assign each hull an unique id with a Counter
  • use a Clipper to clip the original point cloud by hulls - enable Merge Attributes in the Clipper
  • Use a BoundsExtractor on the clipped point clouds to get their min z
  • Use a FeatureMerger (attributes only) to merge the point cloud info onto each hull
  • Use a 3DForcer to elevate the hull to the min z merged in from the point cloud
daveatsafe
Forum|alt.badge.img+19
  • March 22, 2021
Hi @joolek.o​ ,
Please use a BoundsExtractor before the HullReplacer to get the minimum Z of the object, then use a 3DForcer after the HullReplacer to set that value as the Z of the polygon.
  • March 23, 2021
Thanks @daveatsafe​
Please see below:
daveatsafe
  • March 23, 2021
joolek.o wrote:
Thanks @daveatsafe​
Please see below:
Hi @joolek.o​ ,
