HTTPCaller - API Limit Reached!
sarah.h.a
Forum|alt.badge.img+3
Hi all,
Yesterday this worked fine, but today its returning ‘{ "success": 0, "errorMessage": "API Limit Reached!" }’ in _reponse_body column?
What do I need to do to resolve this issue?
Thank you in advance!
Best answer by david_r
You probably can’t do much on your end.
Have a look at the documentation of the API provider, looking for throttling or API limits. You might also want to contact the API provider to ask for a higher limit, if possible.
  • June 12, 2024
sarah.h.a
  • June 12, 2024
@david_r thank you David, I will contact the API providers!
