How to put Z value to a features
  • July 3, 2013
  • 258 views
Hi all,
Im a beginner, need your advised.
i have a DEM data and features (point, line, polygon) data.
How to get the height value from DEM and combine it with the features data. Where basically each features will have a Z value.
How to do it if the output are in shp. or dgn. format.
thanks
  • July 3, 2013
The SurfaceDraper transformer might be a solution. Input the DEM (a raster or 3D grid points) to POINT/LINES port and input the features (points, lines, polygons) to DRAPE_FEATURES port. Then, output features will be draped i.e. Z value of every vertex will be interpolated based on the DEM.
Takashi
You can also try using the PointonValueRasterExtracter then use a ListExploder to extract the "value" attribute.
Many ways to skin the proverbial cat...
