How to obtain the classification of neighboring attributes of the surface features East and West
How do I achieve this effect http://img6.ph.126.net/IzlZ_KPRMTSKD29qP01ZQw==/6598239647028220276.jpg
Best answer by sigtill
A NeighbourhoodAggregator might be usefull? And then afterwards remove those that are not needed (ie the corners) based on the x-y values. You can compare the "centerpoint" of each neighbour and only keep those where the X-coordinates or Y_coordinates are similar to the CenterMapsheet.
