How to go through large set of csv files
wrijs
Forum|alt.badge.img+3
I have a model that has to select rows(points) out of a large collection of large csv files. To encrease performance I want to go throught them one by one. What is the best way to do this?
dustin
Forum|alt.badge.img+30
  • May 8, 2023
You can select multiple files to read at one time in the dropdown of the reader/parameter.image
wrijs
  • May 23, 2023
Thanks for your replay! this does work. But I have found that workspacerunner also works to go through them one by one
dustin
  • May 23, 2023
WorkspaceRunner does use a little more overhead, as it is opening a separate process for each input. But as long as it's working for you. That's the beauty of FME...multiple ways to arrive at the destination.👍
