How to cut polygons by using angle intersecting lines
  • Sep 10, 2020 10:35 AM UTC
  • 95 views
pzwaag_wf
It seems to be very complicated to cut polygons based on the angle between intersecting lines.
Is there a workaround in fme to automate this process?
Enclosed a gdb with sample data. In the gdb source data (BGT) and desired result (new_polygons), GW_OVK represent the line features to be used.
Many thanks in advance!
(FME Desktop version 2019.2.2.0)
Kind regards,
Pim van der Zwaag.
jeand
  • Sep 10, 2020 1:17 PM UTC
Hi Pim,
There is how I would do. Maybe some other guys could have better way to do it, but I think that should work for you!
Regards,
Jean
pzwaag_wf
  • Sep 21, 2020 3:40 PM UTC
​Dear Jean,
Excuse for my delayed reply, I have had a few days off...
 Thanks for your solution. I will try this!
Kind regards,
Pim van der Zwaag.
