How to convert "Heightpolygons" to a smoother homecontour
  • Jan 20, 2017 1:27 PM UTC
  • 5 replies
  • 71 views
jpdenboer
In this image you can see an contour of buildings made of polygons with a height. The contour of the buildings look like columnar basalt now. I want to make a smoother 3d contour of this buildings. Can you help me how to solve this?
jpdenboer
  • Jan 21, 2017 10:17 AM UTC
Is it possible to create a new polygon of the roof by a range of slope angles? Or is there a better way?
itay
Forum|alt.badge.img+19
  • Jan 22, 2017 7:07 PM UTC
Are these polygons generated from point cloud data?
Forum|alt.badge.img+63
It looks like you used a grid to represent the roofs. Have you tried generating a TIN and then clipping that to the building polygons? It'll still be a bit "busy" in some spots (especially buildings with different roof levels, like a church + tower, TIN is really bad at doing vertical lines) but it'll be an improvement over this.
jpdenboer
  • Jan 24, 2017 3:14 PM UTC
These polygons are created from AHN2 data. (goeTIFF files)
itay
  • Jan 24, 2017 10:22 PM UTC
Ok in that case you can try using the pc and not the raster with the brand new PointCloudSurfaceBuilder transformer of FME 2017 RC, or as suggested build a tin.
