How to clamp heights down to WGS84 surface?
Hi everyone!
I have several building models in WGS84 and heights relative to WGS84. How can I clamp those buildings down to WGS84 so that they can be visualized on the surface of WGS84? In other words I need to get rid of the heights!
Thanks in advance!
itay
Forum|alt.badge.img+19
  • January 18, 2017
IF you have a 3D feature and you need it to be 2D then the 2DForcer is what you need.
lifalin2016
Forum|alt.badge.img+41
Maybe 3DForcer with an elevation value of 0 would be better ?
I do not want it to be 2D, I need my 3D model to "land" on WGS84 surface instead of hanging several meters above the surface.
itay
  • January 23, 2017
@lifalin2016 suggestion's sounds like something I would try...
3D Forcer it is, thanks dude! But not with elevation value of 0, but I have feature's elevation as an attribute. So by using arithmetic functions it is possible to do that.
Now I am gonna use 3DForcer to reduce Z values of all points of a feature.
I have a MARK_Z value attribute and need to use Arithmetic Editor so that resulting z value becomes as z - MARK_Z. (z value of every single point of a feature minus MARK_Z attribute of that feature)
But I cannot get current z value in Arithmetic Editor. Any suggestion?
itay
  • January 24, 2017
you can try the @ZValue() function in the Arithmetic Editor
