I am able to create separate Excel files for each data source processed in the batch routine (consecutively), but can't figure out how to append the output of each translation into one file. The schema is the same throughout.
Thanks,
@larue
Thanks,
@larue
Best answer by larue
Select all data sources /files at once in your reader(s) and then make sure to use the same attributes in the writer. I recommend putting a sorter before the writer.
