How can you show an attribute of a vector file in GeoTIFF? (For ex- if I have to show the road name in the GeoTIFF file How can I show it)
  • Feb 25, 2022 10:30 AM UTC
  • 11 replies
  • 81 views
ladisrikanta123
Participant
I have a shapefile of the road and I want to convert it into GeoTIFF But I want the GeoTIFF should show the road name
Forum|alt.badge.img+63
You can try using an Labeller, FeatureColorSetter and then a VectorOnRasterOverlayer.
ladisrikanta123
Participant
I have tried the labeler And I got the result I need but I need to create a new GeoTIFF file from the labeler result. and in the writer part it is occurring error
The original TIFF goes in the VectorOnRasterOverlayer as well, you should only get a single output raster.
ladisrikanta123
Participant
@Hans van der Maarel​ Actually I have only a shapefile of the road with its attribute. So I am trying to convert the road names which I got from the labeler into GeoTIFF format.
Note- A GeoTIFF file which will show only the road name
Aha. In that case I think the ImageRasterizer is probably the easiest one to use. So Labeller -> FeatureColorSetter -> ImageRasterizer.
ladisrikanta123
Participant
Capture2I have used it already but the result is not coming what I am expecting 😑
The number of rows/columns for your output raster refers to the # of pixels (so you're making a 2-by-2 pixel raster here), try increasing that.
ladisrikanta123
Participant
Capture3I have changed pixel size but the name is not coming. Do I need to add any other transformer?
No, this is improvement. Check the result in Photoshop or something, the Visual Preview window can sometimes render rasters a bit funny depending on the zoom level.
ladisrikanta123
Participant
@Hans van der Maarel​ I have tried to render the raster but the result is not coming
I think I've found it. You need to add a TextStroker before the FeatureColorSetter. You'll also need to experiment a bit with the size options you specify in the Labeller and TextStroker in combination with the pixel sizes in the ImageRasterizer.
