How can I transform this data to the Google Earth KM format? What transformers do I have to add?
  • Feb 6, 2021 10:36 PM UTC
  • 117 views
miguelhacar
Forum|alt.badge.img+4
Chage_Cartographic_zoneHi,
I have a “Reader” file in DWG format and in EPSG coordinates: 25830 ((ETRS89-TM30)
This file is located in coordinates UTM Zone 30
I need to change these points from Spindle 30 to SPINDLE 29
I apply the transformers
1. CoordinateExtractor
2. AttributeReprojector
3. AttributeManager (with custom parameters)
So far everything is correct, I see it in FME Preview and it is correct.
My question is this:
Thank you.
danilo_fme
Forum|alt.badge.img+58
  • Feb 7, 2021 12:02 AM UTC
Hi @miguelhacar​
I inserted the Writer Google KML into your Workspace:
Workspace_KMLThe result in Google Earth:
Result_KML
Thanks in Advance,
Danilo
miguelhacar
  • Feb 7, 2021 2:55 PM UTC
Hi @miguelhacar​
Result_KML
Thanks in Advance,
Danilo
Hi Danilo, The solution is not what you say, because I have changed the coordinates to map zone 29 and they continue to be located at map zone 30 when I simply add a KML writer. If it were so simple, this question would not have been asked, in any case, thank you very much.
milo89
Forum|alt.badge.img+27
  • Feb 7, 2021 11:07 PM UTC
Hi @miguelhacar​
You definitely need the KML writer as per @danilo_fme​'s answer.
However, the attribute reprojector doesn't modify the feature geometry. To solve this you can simply add a Vertex Creator (Mode = Replace with point) following the attribute reprojector within your existing workspace or you could use a Reprojector.
Hope this helps.
miguelhacar
  • Feb 12, 2021 11:23 AM UTC
DWG_HUSO30_to_KML_HUSO29
