Help with GeometryReplacer
  • Aug 13, 2013 1:07 PM UTC
  • 14 replies
  • 114 views
koen
Forum|alt.badge.img+14
I'm trying to extract a polygon from a xml document, but no luck so far. This is what I got:
The xml-document looks like this:
<?xml version="1.0" encoding="UTF-8"?> <ns8:MainNode xmlns:ns8="http://www.somesite.com">   <ns8:Name>test</ns8:Name>   <ns8:No>0065525031</ns8:No>
  ......   <ns8:Locatie xmlns:ns3="http://www.opengis.net/gml" axisLabels="x y" srsDimension="2" srsName="epsg:28992" uomLabels="m m">     <ns3:exterior>       <ns3:LinearRing>         <ns3:description xmlns:ns2="http://www.w3c.org/1999/xlink"/>         <ns3:name/>         <ns3:posList>96154 411149 96072 411090 96153 410990 96235 411069 96154 411149</ns3:posList>       </ns3:LinearRing>     </ns3:exterior>   </ns8:Locatie>
  .... </ns8:MainNode >
I'm reading this xml-file with an FME xml reader, with the following setting:
 Configuration Type: Feature Paths
 Elements to match: MainNode
 Flattening Enabled
Now my reader outputs as a whole bunch of attributes:
  Name
  No
  Locatie.axisLabels
  Locatie.exterior.LinearRing.description
  Locatie.exterior.LinearRing.description.ns
  Locatie.exterior.LinearRing.name
  Locatie.exterior.LinearRing.postList
  Locatie.ns3
  Locatie.srsDimension
  Locatie.srsName
  Locatie.uomLabels
I though I should use the GeometryhReplacer to extract the geometry from this, but I'm unsure how to configure it:
-What is the Geometry encoding I should use?
-What is the correct Source Geometry Atrribute
I hope someone can help.
Regards,
Koen Vermeer
Best answer by fmelizard
'So use the xml reader and the replacer set to the xml_fragment.
koen
  • Aug 13, 2013 1:33 PM UTC
My goal is to write everything in an Sql Server Database table.
I don't just need geometry, I also need all the attributes such as 'Name', 'No' (and 20 other I've hidden in my above message behind the dots)
That's why I used a xml reader, how do I get all the other attributes from the text reader output.
Isn't this possible with the xml reader?
fmelizard
Forum|alt.badge.img+22
  • Aug 13, 2013 1:42 PM UTC
koen
  • Aug 13, 2013 1:51 PM UTC
Hi Itay,   (tnx for your quick replies by the way)
I tried that.
-Xml reader
-replacer Geomery encoding: GML
-replacer Source Geometry Attribute: xml_fragment
Execution failes on the replacer:
The @GMLGeometry function failed to parse the GML text from the specified 'xml_fragment' attribute, check the attribute for valid XML data.
fmelizard
  • Aug 13, 2013 1:56 PM UTC
Strange, because it works with the xml example you provided,
Can you pass the xml via a xml validator with succes?
koen
  • Aug 13, 2013 2:23 PM UTC
Strange, don't know where that last fault came from, but when I deleted and added the xml reader again it worked.
Thanks!!
BUT:
It appears that my xml has more than one node with gml data (sorry for not including that the first time)
  <ns8:Pngformaat>     <ns8:OmsluitendeRechthoek>       <ns3:Envelope xmlns:ns3="http://www.opengis.net/gml" axisLabels="x y z" srsDimension="2" srsName="epsg:28992" uomLabels="m m m">         <ns3:lowerCorner>96072 410990</ns3:lowerCorner>         <ns3:upperCorner>96235 411149</ns3:upperCorner>       </ns3:Envelope>     </ns8:OmsluitendeRechthoek>     <ns8:PixelsBreed>2282</ns8:PixelsBreed>     <ns8:PixelsHoog>2226</ns8:PixelsHoog>   </ns8:Pngformaat>
So now the coordinates from Locatie and Pngformaat nodes are combined in one geometry.
Any idea how I can separate this?
fmelizard
  • Aug 13, 2013 2:46 PM UTC
If the geometries are combined (aggregates) the deaggragator will split in into individual features.
koen
  • Aug 14, 2013 7:48 AM UTC
The geometries are combined as a multiple geometry:
This is what the Logger outputs for this:
Coordinate System: `EPSG:28992'
Geometry Type: Multiple Geometry
Front Appearance Reference: `<inherited_or_default_appearance>'
Back Appearance Reference: `<inherited_or_default_appearance>'
Number of Geometries: 2
Geometry Number: 0
Geometry Type: IFMEPolygon
Boundary:
Geometry Type: IFMELine
Number of Coordinates: 5 -- Coordinate Dimension: 2
(96154,411149)(96072,411090)(96153,410990)(96235,411069)(96154,411149)
Geometry Number: 1
Name(utf-16): `OmsluitendeRechthoek'
Boundary:
(96072,410990)(96072,411149)(96235,411149)(96235,410990)(96072,410990)
Each geometry should be saved in a separate field in SQL Server.
I'm not sure how I should do this.
Should I set a name on each Geometry? How do I do that?
fmelizard
  • Aug 14, 2013 8:54 AM UTC
Hoi Koen,
Did you try the deaggregator? that should separate the features.
See https://www.dropbox.com/sh/vn337z1vwis00bw/ByQ_C5XK_Z
Otherwise consider other elements to mach than only the main node.
Itay
koen
  • Aug 14, 2013 10:24 AM UTC
Yes, but the deaggregator splits everything into two features, and it should be saved in sql server as 1 feature with 2 geometry fields.
fmelizard
  • Aug 14, 2013 11:09 AM UTC
So basically you just need to write the aggregates (?) since SQL Server supports that type of geometry.
koen
  • Aug 14, 2013 11:19 AM UTC
So I don't need the deaggregator?
But how do I define which geometry will be saved in which field?
Should I directly connect the GeometryReplacer wtih the SQL Server Spatial Writer?
I'm really lost here...
fmelizard
  • Aug 14, 2013 11:28 AM UTC
Hi Koen,
if the aggregate contains geometries with names that match the spatial columns of the table being written, the geometries will be written to the appropriate columns.
Its always advisable to check the documentation.
Hope this helps
fmelizard
  • Aug 14, 2013 11:33 AM UTC
Forgot to mention that I personally dont have experience with SQL Server and I hope that another group member with experience can pitch in....
So no you dont need the deaggregator , you need to define the geometries names to match the geometry column's names in your destination table.
koen
  • Aug 14, 2013 11:53 AM UTC
Yes, if finally worked.
Already had that this morning, but then I wasn't able to change the names on the geometries, and then I was distracted by experimenting with that deaggregator.
No I got the geometry names set with two serial GeometryPropertySetters which check on the current geometry name and everything works.
Thanks for your help, and your patience with me.
Great to know this site where questions are answered within minutes with useful comments!!
