Give attribute's value for spatial relation
  • Aug 9, 2014 5:54 PM UTC
  • 7 replies
  • 109 views
Hello people,
I have e.g. 30-50 feature types and one most important feature type(XX). Now, I need to assign an attribute value to all feature types, but on the basis of their belonging to the XX. My reader is GML. So, for those who belong to the first XX feature, attribute is 0, for second XX feature - 1 and so on. I do not know how much features of XX type I could have (e.g. assign to all trees on  the parcel same attribute, and for the next parcel do the same - I don't know how much parcels do I have).
What is the best way for doing this?
Can it be done (and how) with SpatialFilter, or with some other (maybe custom) transformer?
Thank you.
Best answer by gio
Hi Aleksander,
I used neighboorhoods polygons and trees/adress points for this one.
As neighboorhoods are identified by name i use its name rather then teh featuretypename.
Here is method2
I intepretated your issue as counter per (spatial)relation.
Zoom in a bit and see the settings.
Using method2 you basically create a count attribute for the Counter. This attribute works as a group by.
Here is result pic (partial table..). Check the count attribute, it starts counting anew for every neighboorhood.
gio
Forum|alt.badge.img+15
  • Aug 11, 2014 2:03 PM UTC
Method 1 of many..
Expose feture_type (expose Feature_Typename at readerlevel, or use other feature_type identifier)
You can use the spatialrelator as you said.
Rename Feature_type to something else  like "target_ft".
Explode relationships.
You can now use "target_ft"  AND "Feature_Typename" as a grouping value.
Built a list grouped by the grouping value.
After that u just explode it, this will give u element_index attribute.
Using list may not be wise if you have an extremely large number (like zillions) of objects though ;).
method 2 of many...
Concatenate "target_ft" and "Feature_Typename".
Use a sorter on this.
Use a counter and use the concatenated attribute as "counter name".
  • Aug 11, 2014 8:43 PM UTC
Gio,
You have helped me few times. I really cann't manage this SpatialRelator and things going with it.
Could you attach workspace SS, just to see what, where and when you put these all stuff? If you could, I will be thankful very lot :)
I am constantly trying to get whatever, and allways getting nothing!
Thanks in advance.
gio
  • Aug 12, 2014 11:15 AM UTC
Hi Aleksander,
Here is method2
  • Aug 12, 2014 1:15 PM UTC
Gio,
big thanks. It works fine, od cource. Thank you.
(Best answer)
  • Aug 12, 2014 2:25 PM UTC
Gio,
Just for a record: When I use ListExploder it (I don't know how) changes my Requestor's feature type to Supplier's feature type, and I get good Join but feature type is Supplier's.
When I remove ListExploder (because I just need to get attribute from Supplier into Requestor's feature types), it keeps original feature types and works good.
I have no idea what is happening, but...
  • Aug 12, 2014 3:14 PM UTC
To avoid overwriting fme_feature_type of Requestors, consider using the AttributeRemover to remove "_relatiohships{}.fme_feature_type" before the ListExploder. If the name is hidden, you can expose it with the AttributeExposer.
Takashi
gio
  • Aug 13, 2014 10:50 AM UTC
yes i understand.
The reason being that the proces i illustrated combines suplier and input featuretypes. So all neighboorhoods (wich i limited to 5 for timereducion) are mapped to the requestors. It takes into account occurence of overlapping supliers.
If u have 1 suplier or non-overlapping supliers, then this is not needed.
When exploding there can be a conflict with attributes, if suplier and requester have same attributes. This is something u always need to watch out for (like Takashi is pointing out)
I mentioned in my first post that u need to rename one of the fme_feature_type name attributes (either requestor or suplier to avoid this conflict).
I usualy use names like
requestor: req_ftype
suplier: sup_ftype
