Getting weird artefacts from ContourGenerator
  • Nov 14, 2022 2:51 PM UTC
  • 6 replies
  • 170 views
aron
Forum|alt.badge.img+16
I am getting some strange spikey artefacts from ContourGenerator. The dataset is a goverment isued DTM, pictured are some sea islands. The data is preprocessed with rastercellrounding and a notatasetter to ensure that the sea surface did not hold any data.
Settings as follows:
First image elev 2.5 tolerance 5
Second image elev 2.5 tolerance 0
Third image is a close up of the the second (elev 2.5 tolerance 0)
Any ideas on how to deal with this?
elev2.5_tol5elev2.5_t
detail
hkingsbury
Forum|alt.badge.img+73
  • Nov 14, 2022 6:30 PM UTC
Are you able to provide the raw data for the two areas above?
itsmatt
Forum|alt.badge.img+48
  • Nov 14, 2022 8:51 PM UTC
Pretty strange for sure. I definitely also recommend uploading the input data. If you really need to move past this you can see if the SpikeRemover helps. You can specify a max angle to remove. It should help remove (some of) the artifacts.
Ideally though we'd want to help you not create them in the first place.​...
aron
  • Nov 15, 2022 7:57 AM UTC
The sample is attached. Might add that I ran the same data through QGIS contour tool without any issues.
itsmatt
  • Nov 15, 2022 9:52 AM UTC
wow - I see what you mean - but it looks a hellova lot better if you don't set the no data value. My guess is that for some reason the NoData is messing with the data.
If you look at the data values where that zoomed in shot of the spike it you can see that its an edge pixel with a value of 3 - greater that 2.5 which was for me, the lowest contour line after removing everything below or at 0 elevation. I guess Ideally you'd like to have a '0' contour line.
imageOne thing which I played around with was to first set NoData to be -0.15 (as it is in the data) Then use the RasterExtentsCoercer (set to Data Extents) to extract polygons, buffer by 5 meters, dissolve to remove overlaps and then clip the input raster into 70 or so parts. Use a counter to add an id to each rater part and then run it though the CountourGenerator (grouping by the id). The whole process is still considerably faster than running the whole image through the contour generator. (15 seconds vs 50 seconds) and the result it pretty similar. The benefit of this approach lets you keep the 0 meter contour.
aron
  • Nov 16, 2022 1:29 PM UTC
Thanks for looking in to this. I generated the contour lines with a script instead. There where also a few artefacts there. But much easier to spot and remove. I will blame the whole thing onthe dataset for now.
hkingsbury
  • Nov 17, 2022 8:01 PM UTC
Garbage in = Garbage out
Slightly off topic, but I do find that sometimes FME is too "exact" and will highlight data "issues" like this more than other pieces of software than my apply some level of generalization or cleaning before performing operations
