GeometryPropertyRemover doesn't seem to work when writing to GML
  • Feb 11, 2022 9:02 AM UTC
  • 100 views
vince_j
Forum|alt.badge.img+3
Hi all,
I am designing an automated proces to transform a File Geodatabase into a GML that is validated by an XSD. The validation fails, because the gml_id is part of the geometry trait of the feature, where this shouldn't be the case. When temporarily turning the validate output parameter off, the result looks like this:
GML1" data-fileid="0694Q00000H4l5hQAB
The red line in the picture above indicates the gml_id I'm talking about. For the XSD validation to work, the gml_id in the geometry needs to be removed.
When checking the attributes of the point feature, I see that the gml_id clearly is a geometry trait of this feature. See the picture below:
GML2" data-fileid="0694Q00000H4l5NQAR With this information, I made the assumption that with a GeometryPropertyRemover, this gml_id could easily be removed, leaving me with only the coordinate system, the dimensions and the actual geometry. I used a GeometryPropertyRemover with the following settings. Note that my client uses FME 2018:
GML3" data-fileid="0694Q00000H4l5SQAR
After running the workspace, the FME Data Inspector shows that the gml_id is removed.
In the resulting GML however, the gml_id isn't removed, it has '-0' appended to it:
GML4" data-fileid="0694Q00000H4l5cQAB
Quite strange, if you ask me. Does anyone have an idea why this happens and how I can solve this? I need that gml_id to be removed..
Cheers,
Vince
Best answer by mark2atsafe
The easiest way to achieve what you ask is to run the data back through an XMLUpdater transformer, like so:
So I read the source data and write it to GML with a FeatureWriter transformer. Then the XMLUpdater reads it back and updates the content. The AttributeFileWriter pushes it out to the file again.
The search path (for me) is:
//fme:Parks/@gml:id
...where Parks is the tag and the at symbol denotes the attribute.
There could be a more official way to do this, but I haven't found it. As far as I can tell, for "features" in GML (as opposed to "geometries") the gml:id is more or less compulsory. That's why (I believe) FME adds them regardless. But it does look like your data is more of a geometry than a feature.
Sorry, I don't know enough about GML to give you a clear answer "why", but the XMLUpdater method should be the "how" that you need.
mark2atsafe
Forum|alt.badge.img+59
  • Feb 11, 2022 11:43 PM UTC
//fme:Parks/@gml:id
  • Feb 16, 2022 6:49 PM UTC
//fme:Parks/@gml:id
Thank you.
Would you please help me formulate an XQuery for the following GML to reach the gml id in the geometry?
<?xml version="1.0" encoding="UTF-8"?>
<gml:FeatureCollection xmlns:img="http://www.geluidgegevens.nl/IMGeluid/1.2" xmlns:gml="http://www.opengis.net/gml/3.2" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gsr="http://www.isotc211.org/2005/gsr" xmlns:dlogger="http://www.armatiek.nl/functions/dlogger-proxy" xmlns:math="http://www.w3.org/2005/xpath-functions/math" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gss="http://www.isotc211.org/2005/gss" xmlns:gmlsf="http://www.opengis.net/gmlsf/2.0" gml:id="idb5c7c638-ba3c-4871-a520-9970d016ce9e">
<gml:boundedBy>
<gml:Envelope srsName="EPSG:28992" srsDimension="3">
<gml:lowerCorner>60065.936400000006 410493.4679999985 -999</gml:lowerCorner>
<gml:upperCorner>146050.5309999995 474731.5689999983 28.769000000000233</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<gml:featureMember>
<img:Diffractor gml:id="NL.img.12345678.27364178.806b84dc-064a-4c36-9908-c7fb4bd9e2ee">
<img:identificatie>
<img:NEN3610ID>
<img:namespace>NL.img</img:namespace>
<img:lokaalID>27364178.806b84dc-064a-4c36-9908-c7fb4bd9e2ee</img:lokaalID>
</img:NEN3610ID>
</img:identificatie>
<img:naam>D1</img:naam>
<img:omschrijving>Test_diffractor</img:omschrijving>
<img:breedte>1</img:breedte>
<img:statusZwevend>false</img:statusZwevend>
<img:diffractoreffect>
<img:WaardePerOctaafband>
<img:band31Hz>0.5</img:band31Hz>
<img:band63Hz>0.5</img:band63Hz>
<img:band125Hz>0.5</img:band125Hz>
<img:band250Hz>0.5</img:band250Hz>
<img:band500Hz>0.6</img:band500Hz>
<img:band1000Hz>0.8</img:band1000Hz>
<img:band2000Hz>0.5</img:band2000Hz>
<img:band4000Hz>0.5</img:band4000Hz>
<img:band8000Hz>0.5</img:band8000Hz>
</img:WaardePerOctaafband>
</img:diffractoreffect>
<img:geometrie>
<gml:LineString gml:id="NL.img.12345678.27364178.806b84dc-064a-4c36-9908-c7fb4bd9e2ee-0" srsName="EPSG:28992" srsDimension="3">
<gml:posList>84611.99240000173 451716.78979999945 0 84669.93499999866 451782.63369999826 0</gml:posList>
</gml:LineString>
</img:geometrie>
</img:Diffractor>
</gml:featureMember>
I need to remove gml_id in Line 35
vince_j
  • Feb 18, 2022 8:06 AM UTC
Hi Mark,
Thank you for your response. '//gml:Point/@gml:id' did the trick in my scenario.
Cheers,
Vince
