GeometryExtractor or Geometry Template in XMLTemplater
I use XMLTemplater to make my GML file. But I can not cope with Geometry templates (I am new in using this and cann't find some tutorials for it). Because I cann't get geometry (point, curve, surface and multi-surface) from my feature, I used GeometryExtractor to extract my geometry into new attribute and then I simply store it where I need.
But GeometryExtractor gives me this:
<gml:MultiSurface xmlns:gml="http://www.opengis.net/gml" srsDimension="2">
<gml:surfaceMember>
<gml:Surface>
<gml:patches>
<gml:PolygonPatch>
<gml:exterior>
<gml:LinearRing>
<gml:posList>6436765.27 4948428.28 6436763.31 4948427.66 6436766.45 4948422.08 6436770.67 4948418.79 ...  6436765.27 4948428.28</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:PolygonPatch>
</gml:patches>
</gml:Surface>
</gml:surfaceMember>
</gml:MultiSurface>
I don't have point separators here, as well as the appropriate signs (< >). What I need to do and how, to succeed in this? Does anyone has some tutorial (not FME Help) for this).
Thanks
gio
Forum|alt.badge.img+15
  • July 29, 2014
You can use  for instance a StringReplacer opn the geomtry attribute to replace &lt; with < and &gt: with >
If you then use GeomteryExtractor you get this:
And point separator is irrelevant?
gio
  • July 29, 2014
Coordinates are tuples.
There is no seperator between them.
Or is this not what u ment by "point separator"?
it says aggregate but also invalid geometry...because the bit u posted is not complete i guess. The pic is from your posted bit.
Yes, I deleted part of the points because there is too many of them.
The thing is that I cann't decode &lt; with < and &gt: with > (I use textdecoders unsuccessfully).
