Geographic Transformation
  • May 26, 2016 5:13 PM UTC
  • 6 replies
  • 138 views
Hi! How to add custom 7 parameter geographic transormation (for example between MGI-C and WGS84)? Reason why i want add new transformation is because parameters in FME is not accurate enough for surveying purposes, so i want add new geographic transformation with official parameters released from state surveying administration
Best answer by fmelizard
Hello @zolja87 . You can define a custom transformation in the <FME_Install_Folder>/Reproject/MyCoordSysDefs.fme file. There are examples in the file itself as well as information on the constants to use for each of the transformation methods (including 7 parameter), in our FME Workbench documentation. Here is a link to get you started: http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/CoordSys/Geographic_Transformations.htm
fmelizard
Forum|alt.badge.img+22
  • May 27, 2016 6:15 PM UTC
  • May 29, 2016 7:55 PM UTC
Thank you for the informations @CandaceAtSafe
If i give you my parameters can you please generate me a file cause it looks difficult to me
daveatsafe
Forum|alt.badge.img+24
  • May 11, 2020 9:44 PM UTC
Hi @shefqetlulja,
We have an interactive utility that lets you define custom coordinate systems, that can be found at fme.ly/coordsys.
Hi @shefqetlulja,
it is not for custom transformation? it is for custom coordinate systems as i understood
daveatsafe
  • May 15, 2020 3:30 PM UTC
Sorry - that's true. Please provide the transformation parameters, and I will create a definition for you.
