Flip label for 3D view
  • Feb 17, 2022 12:29 PM UTC
  • 76 views
hrinn
Forum|alt.badge.img+5
I have a set of labelpoints that I want to flip to make it readable from a viewpoint from the side in 3D. Is there a transformer that does the trick? Thanks
Best answer by itsmatt
I have turned the text to a solid so i just want to flip it from horizontal to vertical.
image.pngNot sure about the format yet, probably dwg or ifc
ok nice - then you will need to use a 3DRotator transformer. You will first need to identify the Custom Axis or Rotation - I think just the center point of the word and then probably the x axis unit vector (1,0,0)
itsmatt
Forum|alt.badge.img+48
  • Feb 17, 2022 12:35 PM UTC
what's the output format?
hrinn
  • Feb 17, 2022 12:42 PM UTC
itsmatt
  • Feb 17, 2022 12:55 PM UTC
hrinn
  • Feb 17, 2022 1:12 PM UTC
The 3D rotator did it. Thanks
