Expose Data Source info from Feature Layer/ArcMap
marta.podsiad
Forum|alt.badge.img+9
How can I expose the information that are visible in the Properties/Source tab of feature layer image
nielsgerrits
Forum|alt.badge.img+53
I don't know of a way to do this. I think you need Python / ArcPy for this, but not sure.
dustin
Forum|alt.badge.img+30
  • January 23, 2024
Definitely need ArcPy using the Describe object properties (PythonCaller/PythonCreator). The link can provide more info. Looks like the Z and M values are available, but Compression doesn't look to be.
https://pro.arcgis.com/en/pro-app/3.1/arcpy/functions/featureclass-properties.htm
