Dissolve overlaps in a parcel polygon
  • December 11, 2014
  • 47 views
I have a parcel polygon in which there are overlaps and this prevents one from seeing the underlying polygons - see the images below. The second image is accomplished by duplicating the layer - with one with a polygon fill and the other with no fill. A sample dataset is available here https://www.dropbox.com/s/qkaz8au08inffdb/parcel.zip?dl=0
gio
Forum|alt.badge.img+15
  • December 11, 2014
You want to dissolve it? R u sure? Dissolve wil result in the same polygon as the yellow one.
I assume you want to use AreoOnAreaOverlayer or Topologybuilder.
gio
  • December 11, 2014
Btw
The big poly is last in the data, if i open it in inspector is see the "underlying" poly's. It has the highest GID.
I get an error trying to open it in Arcmap though..
