Deleting output data in FME Server based on their age
  • 10 July 2017
  • 10 views
mygis
Forum|alt.badge.img+12
Hello,
I am trying to delete output data generated by a workspace published under the job submitter service. My understanding is that we need to :
1. Change a few things in the fmeEngineConfig.txt file.
2. change the FME_RESULT_LIFETIME to the number of seconds we want.
3. Change the FME_PURGE_INTERVAL to the number of seconds we want.
4. Set the FME_WORKING_DIR to the folder we want this to happen.
5. Save the abpve config file
6. Restart FME Server.
Is this correct? Did I missed out something?
Thanks.
Lyes
Best answer by stalknecht
I think setting FME_WORKING_DIR is unnecessary.
Here are the instructions:
Increasing the time files remain
Consider using cleanup tasks in the webinterface:
Server Cleanup
stalknecht
Forum|alt.badge.img+19
Server Cleanup
