Data from CoquitlamInfrastructureAR.fmw example workspace
  • Dec 15, 2020 4:31 PM UTC
  • 35 views
arnovananrooij
Forum|alt.badge.img+5
I'am working on my first Augmented Reality model in FME. I have data from cables, sewers etcetera. As an example I found the webinar (https://www.safe.com/webinars/data-in-the-real-world-fme-ar-and-fme-data-express/). This webinar comes with some example workspaces. The workspace CoquitlamInfrastructureAR.fmw seems to do a lot like I would like to do. It looks way more complicated than I'd expected. It's even harder to go through cause the data used is missing. There's a feature reader reading shapefiles, bur the shapefiles are not included. There's also a google sheets reader that I can not use.
Can someone provide the data?
Thank you in advance,
Arno
rahulsharma
Forum|alt.badge.img+12
Hi @arnovananrooij​
This workspace uses the open data of the City of Coquitlam;
https://coquitlam.maps.arcgis.com/apps/Cascade/index.html?appid=26ed37ee4167495dbb92e2798aa2b968
The following shapefiles were used:
  • Cadastral
  • Drainage
  • Sanitary
  • Street_Lighting
  • Transportation
  • Water
You should be able to download the data from the portal linked above
