Create Polygons fro stair cases
  • Jan 12, 2018 4:12 PM UTC
  • 32 views
Hi all,
I am having a problem turning stairs into one polygon and I could use some guidance. First task was to extend the multiple horizontal lines to intersect with the vertical lines, to create stairs. However, I need to extend the horizontal and vertical lines in the blank space (circled) to to meet each other. I have tried anchor snapping with generalizer, NeighborFinder with AnchorSnapping and it doesn't work very well. Attached is an image of my workflow, so far.
Thanks for any advice!
fmelizard
Forum|alt.badge.img+22
  • Jan 12, 2018 5:53 PM UTC
Hi @david_prosack88 Maybe try an AreaBuilder first and use an Extender on the remaining dangles? Then Snap and Intersect, build all areas and lines again, and finally Dissolve at the end.
