I want to copy files from one folder to another in BIM360/ACC with AutodeskBIM360DocsConnector, and in BIM360/ACC there is a Default Attribute column for Description. And when I copy them in FME the Description does not come with.
In AutodeskBIM360DocsConnector there is no option in Attributes to Add called Description.
Any suggestions for how I can get the Description in the copy process? 🙂
Best answer by danii
I got this answer from Autodesk Forge support:
"I hate to disappoint you, but it is true Description field has not been exposed by the API. We have had a wish ticket: FDM-3124. We are pushing engineer team to implement.
It is a bad workaround, while it might be way you create one custom attribute and input description there. API with custom attribute is available."
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
