converting Shapefile polygon zm to polylines with z values
  • January 24, 2013
  • 251 views
Hi.  I am looking for a way to convert Shapefile zm polygons to Shapefile polylines whereby the z values are inherited along the line segments.
  • January 24, 2013
Hi, how about GeometryCoercer?
fmelizard
Forum|alt.badge.img+22
  • January 25, 2013
You can extract the m with the measureextractor, change the geometry with the geometrycoercder and force it to 3D (using the m) with the 3Dforcer.
Hope this helps.
  • January 25, 2013
Thank you.  I am new to FME, and am having trouble modelling the workflow. Based on the answers provided I am: Reading Polygon zm - Geometry Coercer Transformer - 3D Enforcer - Writing New File.  Does anyone have a schema I can use as a template to get started?
