Converting CAD parcels to GIS in FME,
  • September 3, 2014
  • 8 replies
  • 86 views
jamal
Forum|alt.badge.img+5
In ArcGIS, it is quite easy to convert parcels from CAD to GIS as shown in the model below. In CAD, parcels are drawn as lines inside which numbers are drawn.
1. The lines are converted to polygons
2. The texts are converted to points that have text values as attribute
3. The texts are migrated to polygons by the command “spatial join”.
In FME, I couldn’t know how to
1. Convert lines to polygons
2. Convert text to points
3. Migrate text to polygons
How can I build an equivalent workbench to the model above?
Thank you
Best
Jamal
  • September 3, 2014
Jamal,
See attached screendumps
Output in ArcGIS
SmartCleaner may come in handy - download from FME Store - not essential but useful.
Hope this gives u some ideas
Regards
Howard L'
jamal
  • September 3, 2014
Many thanks Howard for the help,
The screenshots are not clear. Could you please share the workbench itself?
  • September 4, 2014
In your case, it's quite easy also with FME. For example:
  • September 4, 2014
The essence of my data flow is completely same as Howard's suggestion. I think Howard's suggestion has more capability for some other dirty datasets.
  • September 4, 2014
Jamal,
In FMEpedia (or any) webpage, if image too small / difficult to read.........
Depending upon your browser.......
Right click on image - save image as - then view outside of the web page eg in photoshop etc
OR
Zoom in directly on web page (depends on browser) - with Firefox click <Ctrl +> on keyboard. Other browsers have similar zoom functionality
Not possible to attach workbenches in FMEpedia unfortunately otherwise I would post it for you no problem. File type attachments are limited to images only
Hope this helps
Howard L'
jamal
  • September 4, 2014
Many thanks guys for the prompt help,
In my case, the CAD file has two main layers: Parcels_Geometry and Parcels_Texts
http://www.mediafire.com/download/doxp7pm0ozd1fh9/Parcels_02.dwg
I use the “tester” tool to catch these two layers first. It does catch the Parcels_Geometry layer but fails to do so for the Parcels_Texts.
Why the “tester” tool fails to catch content of the Parcels_Texts layer?
jamal
  • September 4, 2014
Now, I’m able to extract these two layers with the tester.
Thank you
jamal
  • September 4, 2014
Many thanks Howard and Takashi for the massive help. With your valuable input, I could build the entire workbench that converts CAD parcels into GIS format.
